Rootasting 【乡味知约】{祖传烙饼,排队2小时也不一定买得到}
查看1646 | 回复0 | 2017-5-25 06:45:29 | 显示全部楼层 |阅读模式
济南男子祖传烙饼美食,日做 16个,排队2小时也不一定买得到
image?imageUrl=http%3A%2F%2Finews%2Egtimg%2Ecom%2Fnewsapp%5Fmatch%2F0%2F1590023770%2F0&src=feeds&subsrc=read&t=0&r=17&rspimgflag=0&imgflag=15&filesize=41708&referUrl=http%3A%2F%2Fkuaibao%2Eqq%2Ecom%2Fs%2F20170524A0A5M400.jpg
跟往常一样,吴兴强早早得来到了他的“吴家锅饼”店,准备开始一天忙碌的工作。饼店坐落在济南芙蓉街北头,虽然门店看起来并不起眼,但是却是一家百年老店。吴兴强已经是这间饼店的第三代传人,多年来,他做出来的美食受顾客的欢迎,吃过的人赞不绝口。
image?imageUrl=http%3A%2F%2Finews%2Egtimg%2Ecom%2Fnewsapp%5Fmatch%2F0%2F1590027167%2F0&src=feeds&subsrc=read&t=0&r=17&rspimgflag=0&imgflag=15&filesize=37151&referUrl=http%3A%2F%2Fkuaibao%2Eqq%2Ecom%2Fs%2F20170524A0A5M400.jpg
吴兴强做的是纯手工双面芝麻锅饼,跟市面上机器生产的锅饼不同,他的锅饼使用的是碳火烤制,加上祖传独有的配方,成品焦脆可口。一个成品大约直径40厘米,重约3.5斤。
image?imageUrl=http%3A%2F%2Finews%2Egtimg%2Ecom%2Fnewsapp%5Fmatch%2F0%2F1590029162%2F0&src=feeds&subsrc=read&t=0&r=17&rspimgflag=0&imgflag=15&filesize=34928&referUrl=http%3A%2F%2Fkuaibao%2Eqq%2Ecom%2Fs%2F20170524A0A5M400.jpg
吴兴强发面用的是老面,据说这样做出来的成品咬起来才够筋道,而且可以存放的更久。
image?imageUrl=http%3A%2F%2Finews%2Egtimg%2Ecom%2Fnewsapp%5Fmatch%2F0%2F1590031063%2F0&src=feeds&subsrc=read&t=0&r=17&rspimgflag=0&imgflag=15&filesize=38239&referUrl=http%3A%2F%2Fkuaibao%2Eqq%2Ecom%2Fs%2F20170524A0A5M400.jpg
每一次做饼,配方需要经过准确的计算,多一点和少一点做出来的味道完全不同。
image?imageUrl=http%3A%2F%2Finews%2Egtimg%2Ecom%2Fnewsapp%5Fmatch%2F0%2F1590033832%2F0&src=feeds&subsrc=read&t=0&r=17&rspimgflag=0&imgflag=15&filesize=38399&referUrl=http%3A%2F%2Fkuaibao%2Eqq%2Ecom%2Fs%2F20170524A0A5M400.jpg
揉好的面团,老吴用一根手臂大小的木棍反复压挤,有点像竹升面的做法,每一个饼需要反复按压超过200次。
image?imageUrl=http%3A%2F%2Finews%2Egtimg%2Ecom%2Fnewsapp%5Fmatch%2F0%2F1590036157%2F0&src=feeds&subsrc=read&t=0&r=17&rspimgflag=0&imgflag=15&filesize=32684&referUrl=http%3A%2F%2Fkuaibao%2Eqq%2Ecom%2Fs%2F20170524A0A5M400.jpg
接下来用擀面杖把面团压薄约2厘米。
image?imageUrl=http%3A%2F%2Finews%2Egtimg%2Ecom%2Fnewsapp%5Fmatch%2F0%2F1590038285%2F0&src=feeds&subsrc=read&t=0&r=17&rspimgflag=0&imgflag=15&filesize=45422&referUrl=http%3A%2F%2Fkuaibao%2Eqq%2Ecom%2Fs%2F20170524A0A5M400.jpg
成型的饼洒一点水,再撒满满的芝麻。
image?imageUrl=http%3A%2F%2Finews%2Egtimg%2Ecom%2Fnewsapp%5Fmatch%2F0%2F1590041270%2F0&src=feeds&subsrc=read&t=0&r=17&rspimgflag=0&imgflag=15&filesize=44612&referUrl=http%3A%2F%2Fkuaibao%2Eqq%2Ecom%2Fs%2F20170524A0A5M400.jpg
烤锅饼使用的是特制的炉灶,先把蜂窝煤烧着,等到没有明火的时候就可以放上锅烙饼了。
image?imageUrl=http%3A%2F%2Finews%2Egtimg%2Ecom%2Fnewsapp%5Fmatch%2F0%2F1590043159%2F0&src=feeds&subsrc=read&t=0&r=17&rspimgflag=0&imgflag=15&filesize=48035&referUrl=http%3A%2F%2Fkuaibao%2Eqq%2Ecom%2Fs%2F20170524A0A5M400.jpg
放上平鏖,有芝麻的一边朝下,先加上锅盖烤10分钟左右,反过来再烤20分钟就可以取出来。
image?imageUrl=http%3A%2F%2Finews%2Egtimg%2Ecom%2Fnewsapp%5Fmatch%2F0%2F1590045059%2F0&src=feeds&subsrc=read&t=0&r=17&rspimgflag=0&imgflag=15&filesize=30710&referUrl=http%3A%2F%2Fkuaibao%2Eqq%2Ecom%2Fs%2F20170524A0A5M400.jpg
取出来的饼在上面戳10几个小孔透气,这样才能保证全部熟透。一张锅饼形成,经过前前后后需要花费90分分钟。
image?imageUrl=http%3A%2F%2Finews%2Egtimg%2Ecom%2Fnewsapp%5Fmatch%2F0%2F1590047586%2F0&src=feeds&subsrc=read&t=0&r=17&rspimgflag=0&imgflag=15&filesize=33683&referUrl=http%3A%2F%2Fkuaibao%2Eqq%2Ecom%2Fs%2F20170524A0A5M400.jpg
像这样的锅饼,老吴每天只做16个,卖完即止。锅饼按斤卖,一个锅饼也就20-30块钱。谈到为何不扩大规模,老吴表示那样就保证不了品质了,我宁愿少赚点钱也不能让祖宗的手艺毁在我手上啊。在如今的市场经济时代,这样的品质实属难得。
image?imageUrl=http%3A%2F%2Finews%2Egtimg%2Ecom%2Fnewsapp%5Fmatch%2F0%2F1590053416%2F0&src=feeds&subsrc=read&t=0&r=17&rspimgflag=0&imgflag=15&filesize=51742&referUrl=http%3A%2F%2Fkuaibao%2Eqq%2Ecom%2Fs%2F20170524A0A5M400.jpg
老吴的锅饼从来不愁卖不出去,多年来靠着良好的口碑,每天这个不起眼的小门店都站满等待的顾客,为了吃上老吴的美食,顾客即使等候2个小时也愿意,即使排队了也不一定买得到。
